TCP Front Suspension
Discussion in 'The Stable' started by RancheroRandy, Oct 25, 2021.
  1. Hillbilly
    Cool ! I like that design.
  2. RancheroRandy
    RancheroRandy In Overdrive
    I should mention that lubing grease fittings was always very problematic and I usually had to get one of my sons to assist...I found a wonderful grease gun fitting on-line: Lock 'N Lube that works just as advertised (a toss-up sometimes buying stuff over the internet) and has made for me trying to do a frustrating task a breeze now. :) lock n lube1.jpg lock n lube2.jpg
    The one I had was either a Snap-On or Mac fitting, that snapped on to the zerk fitting at a 90° angle. I've been trying to find a new one ever since I lost the old one.
    It was perfect for those Ford upper bushing zerks, so holes would not have to be drilled in the shock towers.
  4. RancheroRandy
    Got my new front end aligned....my eyeball job wasn't too, too bad except the toe that I knew was a little screwy. It was very interesting to watch (on the techno-monster alignment machine) how dynamic alignment is and by adjusting just one little thing affect the others. It took 2 hours to do (my mechanic is a perfectionist) but it certainly did improve the already improved handling and steering. For those interested here are the final results: Camber .5 Neg degrees; Caster R.3.0 degrees, L. 2.5 degrees due to road crown, Toe-in 1/8"
