The "Rock"
Discussion in 'The Stable' started by HuevosRanchero, Jul 25, 2011.
  1. HuevosRanchero
    you can see the right side blocking plate...I believe its possible a thunderbird unit will fit inside this
    box if this plate is removed but don't quote me on it.
    touched up the evap box before putting the pipes through.....
    new heater hose vacuum valve....they are still available new, should probably have gotten the electronic one but I've already added so
    much wiring to this thing.........
    added a couple of these polished clamp fittings to spice up the firewall opening a bit......they aren't cheap but they are well made....
    need to sort out this rats nest and get a few shots of the vacuum motor I modified for the heater flapper door.....lots of matching
    part numbers but couldnt find one with the exact arm length so I got a longer one and drilled a mounting hole and it works great
    so far....didn't get any shots outside the car but will get one of it installed...just need a bit more time. Cheers everyone.
    Buds 67, As Is '66, Hillbilly and 2 others like this.
  2. andrewok1
    Nice work as always Huevos...
