Tilt column
Discussion in 'General Ranchero Help' started by Dry heat bob, Jul 31, 2020 at 9:59 PM.
  1. Dry heat bob
    Dry heat bob In First Gear
    Planning a tilt column upgrade/ 1958 ranchero any one know length I need? I’ve heard 30 inch.
  2. 5.0 Chero
    your best bet is to measure yours and not rely on someone else measurements
    The Wrench likes this.
  3. Dry heat bob
    That’s the obvious but don’t know where to measure from /to
  4. Dry heat bob
    I’ll figure it thanks
  5. Hillbilly
    Take your time and consider all your options. Do you want a column shifter and the work to make it fit, tilt, ect ? Look at "I Did It " columns for ideas or consider other columns from standard cars to see what possibilitys are out there.
  6. Dry heat bob
    Looks like it’s going to be a big job. I want the borgeson power/ steering box & tilt column. Might have to jack up engine to access steering box. Just gathering parts right now. So I’ll keep you posted. Thanx
