Tires and rims
Discussion in 'General Ranchero Help' started by GWD105, Oct 7, 2025.
  1. GWD105
    GWD105 In First Gear
    I have a 1979 Ranchero and I believe it came from the factory with 14" rims. Can I put 15" mag wheels on it?
  2. 1978GT
    My 78 runs P245/60SR15 BF Goodrich Radial T/As on 15x8 American Racing AR-23 wheels.
    Much better setup than the 14 inch stocks.
    No issues whatsoever.
    77-78-79 all same body and platform.
    Check with a local tire dealer to ensure fitment before you buy.
  3. GWD105
    Great thanks so much for your response
  4. 1979 RANCHERO GT
    You will need to check your speedometer for how far off it it is reading. Simple fix.
  5. pmrphil
    Only if the overall tire height is vastly different than the original - an inch won't really matter much.
    Buds 67 likes this.
  6. 1978GT
    4% increase in my case. I chose to ignore it, but you can correct this with a different combination of speedometer drive and driven gears. There is an engineer on this site who can give you some more info.
  7. GWD105
    Great information thanks to all that responded
  8. aquartlow
    "an inch won't really matter" Uh......, that's not what she said. :D
    Buds 67 and pmrphil like this.
  9. aquartlow
    FWIW, years ago I tried a set of Weld 15x10 Draglites with 5" backspacing with 325/50/15 Hoosiers on the rear of my '79, they fit quite good with no rubbing. I realize probably way more tire than you need or wheel width wanted, just letting you know what I found for the space/clearance limits. Hope this info is somewhat helpful
  10. 1978GT
    The best way to check tire clearance is to turn the wheels lock to lock with the vehicle raised up.
    An inch matters more in the front than in the rear.
    That IS what she said.
    Saff54 likes this.
  11. pmrphil
    Funny, I would have thought just the opposite :eek::cool:
  12. Clark
    I put 15"x8" Mag 500 wheels on my '75 Ranchero years back with no problems - until they rusted.
    So I bought a new set from Kentucky Mustang in 2025 only to find that the offset had changed and the rears were in contact with my Lincoln disk brake calipers. Wheel spacers fixed this but best to check for clearance when installing.
    By the way, I run 235/60x15 tires on the front and 275/60x15 tires on the rear.
    IMG_5560.jpeg on the rear.
    Buds 67, Lincolnut and Kiwirancher like this.
