Trip TO Tennessee 351 -C MOTORS
Discussion in 'Ranchero Pics' started by andrewok1, May 12, 2019.
  1. andrewok1
    More pictures to be added- later -camera chip malfunction -2 motors & 2 transmissions full load IMG_20190427_101426 (1).jpg IMG_20190427_101435 (1).jpg IMG_20190427_101447 (1).jpg IMG_20190427_101511 (1).jpg IMG_20190428_110709 (1).jpg IMG_20190428_110734.jpg
    LSChero likes this.
  2. LSChero
    Full load I guess!Every bit of 1500#!Iama sellen my F250 gitten me one of dem dare sploders.
    andrewok1 likes this.
  3. andrewok1
    that what we thought 1500, run 85 down the high way16.0 to the gallon, tires aired up to 45lbs 4.0 Mazda motor
  4. cbolt
    Palm Coast, FL
    Cool Goat in the background there.
  5. Hillbilly
    I don't cull anything that is old anymore, you never know what turns up in my back yard.
  6. andrewok1
    hell Hillbilys back yard is like the Bermuda triangle -objects (Vehicles )just appear with unknown rhyme or reason ,
  7. Hillbilly
    Never thought about it in that context. I think you just coined another truism. Old Ford trucks on stage lately. Next week, who knows ?
  8. andrewok1
    I envision a Lamborgini showing up soon,fitting right in
  9. Doc76251
    Doc76251 In Fourth Gear
    Virginia Beach, VA
    Damn Hillbilly, with as many Lincoln's as you have in the front row you HAVE to have the serpentine set up from a 5.8LW w/ a Saginaw P/S pump, A/C and 3G ALT sitting in the weeds. Not having any luck finding a 94 - 96 E-250 van.
    Cheers,
    Doc
  10. Jeff B
    I like the high crop "crane". IHC?
  11. LSChero
    Got any of these hiding in the iron farm Hillbilly?Like to have one in my yard!
  12. LSChero
    Check under the hoods 80s F series and full size broncos Doc,may get lucky.Wonder if 5.0 serpentine brackets would work on 351W,heads are same with wider span,not sure on water pump?
  13. Hillbilly
    Used the last serpentine like that on a 53 F-100 but I will check at a friend's place. That looks like Lady Gaga's Lightning. I finally tired of not being able to tow a car trailer behind my black 93 and sold it to a friend from NewOrleans. Different from a regular F-150, not enough room to air-bag it easily. Ol' tractor is a 1962 IHC 560 diesel, has hydraulics that can move 1/8 of an inch if you are gentle with the controls. Got two 90 Lincolns with 5.0's but they are different from the Mustang serp. Lincolns had two serpentine belts, one ran the a/c and smog pump, the other did the alt. steering and water pump. Alt. and a/c were on the opposite sides too. Haven't counted Lincolns lately, had 30 at one time. Keeping the later 4.6 Lincolns, easier to give them Coyote engines.
  14. Doc76251
    Virginia Beach, VA
    I've thought about looking at 5.0L but none of them came with the Saginaw PS pump, hell I can't even find the part number for the PS / AC bracket that fits them. The holy grail would be finding one that has the Sag AND a hydroboost brake system already in place. It would be my "luck" that it would be a 94 - 96 5.8L because then I would have to buy the whole motor as those years have a roller cam. For some reason this year the copperhead and moccasin population has exploded and all the JY's are in or near swamps. I ran across 6 in the span of 30' and decided against going further.
    Cheers,
    Doc
  15. 5.0 Chero
    Do not need a Sag pump for hydrobooster I used the ford pump with out issues so did ford.... I was even able to find a plastic tank with 2 return ports
  16. 5.0 Chero
  17. Doc76251
    Virginia Beach, VA
    Thanks Carl, I'm gonna have to sit down and read all that and take notes!
    Cheers,
    Doc
  18. LSChero
    I cut tee in return line from cooler to resv.Seems to work fine so far.
  19. uk ranchero
    uk ranchero In Second Gear
    i did the same. no problem.
    original ford pump
