Truck Conversation
Discussion in 'General Ranchero Help' started by Rods N Restos, Nov 25, 2019.
  1. Rods N Restos
    Rods N Restos In Fourth Gear
    South Jersey
    I made a signature for my profile and saved it but doesn't show up when I post.
    Is the signature option turned off on the forum or maybe just my profile?
  2. 72GTVA
    It is the same window that you listed out your vehicles in red per your post above. Looks like you put something in the "about" field in your profile page.
  3. Rods N Restos
    South Jersey
    Is it that I don't see my signature but you do?
    On other forum I was on I could see the signature under my comments.
    I don't see it when I reply
  4. 72GTVA
    Not turned off, you put it in the wrong place.
    You edit your profile, and place your signature in the "signature" section:
    Open the attached to see where you change the information in your "Profile Info" tab.
  5. Rods N Restos
    South Jersey
    I clicked on Signature in the drop menu when you click on your screenname and added it there and saved it
  6. Rods N Restos
    South Jersey
    The list of cars is my signature.
    The "About" info is what I do for living and in correct location is so is my signature and even added my forname and saved changes but I don't see my signature when I post
  7. Rods N Restos
    South Jersey
    Could my recent screen name change have anything to do with why my profile doesn't work correctly?
    I can only edit Profile by the drop menu and click on Signature.
    Is there a character limit that might effect it showing up?
  8. 72GTVA
    No on the change effecting it, and there may be a limit such as the entire "War and Peace" (the book) might be a little much. Otherwise, you should be able to do anything you want until an Admin or Mod decides something is inappropriate.
  9. Rods N Restos
    South Jersey
    Tried shortening it to just the the Ranchero's and it still wouldn't post.
    Think there is a software problem,when was that last updated?
  10. 5.0 Chero
    Looks like it there to me
  11. Rods N Restos
    South Jersey
    Ok that was my question that didn't get answered.
    Does it appear for other members to see but not myself?
    On the GTS Forum years ago the signature could be seen by both myself and all members and Admin when I replied on posts.
    I do NOT see my signature when viewing a post
    This is what I see after reply,no Sig
    Saff54 likes this.
  12. colnago
    I see my signature when I make a post, right above where it says:
    "colnago, 1 minute ago Edit Delete Report Like +Quote Reply"
    Looks like you just changed your signature, because now I see your Gran Torinos. I only saw your Rancheros before. Everything shows up in red.
  13. 5.0 Chero
    not sure what shows up on a phone I use a PC and mine shows up for me
  14. handy_andy_cv64
    Phones held vertically, will not show extras, but hoizontally, should.
    However, on my phone, R&R's sig does not show up.
  16. handy_andy_cv64
    A screenshot from mine. Thought: perhaps when not using a 'smartphone-friendly' app for the site, the extras, such as sigs, are dropped, to reduce bandwidth data transfer?
  17. Rods N Restos
    South Jersey
    Joseph I see all that just not My signature
    I see yours though.
    Not sure why it's in red as I tried to switch to black and yes I added our 2 Gran Torinos as it's all about having the 3 72's even though the 76 body shell with title will be on 72 frame is being used to build a 72 GT ProStreet Replica to go with the two 72 Gran Torinos
  18. colnago
    I tried to make my signature black text, too, but couldn't figure it out. I figured that red is just one of "those things" on this forum. If you figure it out, let us know.
  19. Rods N Restos
    South Jersey
    Check it out now, changed each vehicle to color they are originally.
    Had to use orange on wagon as they don't have a Medium Yellow Gold
    And hard to read bright yellow.
    colnago likes this.
  20. 72GTVA
    Software was recently updated concurrent with renewals and routine updates/security enhancements.
    Bear in mind that this site as most others originated using UBB coding from when online bulletin boards were in their infancy - and legacy features from the old boards including the use of UBB Code is still supported.
    The site default color for signatures is red, and it can be changed as you've discovered, and if someone quotes a post in their signature as many do it appears in the format of a quoted post. Why you aren't seeing your signature appears isolated to you. Every time I look at any of your posts your signature is present.
    I'm happy to chase a problem as is Bill (the site owner). Unfortunately I can't find a problem with the board as of this writing.
