Valve covers
Discussion in 'Ranchero Tech Help' started by toyroom, May 17, 2017.
  1. toyroom
    toyroom In Third Gear PLATINUM MEMBER
    We're looking on dressing up our engine with some new aluminum valve covers and an air cleaner.
    We were wondering if anyone experienced any issues with the very inexpensive brand "Cricked Engines Performance" apposed to the more expensive "Scott Drake" or "Holley" brands.
    I've heard that the cheap brands have a tendency to leak.
  2. russosborne
    russosborne In Third Gear
    Glendale Arizona
    It's Cricket, not Cricked. :D Had to look them up.
    Since they are aluminum, you are probably okay. The leakers tend to be the cheap stamped steel versions. Although anything is possible.
    Russ
  3. ribald1
    Many of the Chinese aluminum ones warp when heated and leak.
  4. 5.0 Chero
    Good price on those, good polish on them also.
  6. toyroom
    I might be wrong but I thought that the Boss 302 heads were slightly larger than the regular 302 heads, and I think they have two more bolt holes.
    Thanks for the heads up!!
  7. 5.0 Chero
    Correct was not sure what power plant you had
