Valve leaking
Discussion in 'Non-Automotive Stuff' started by RancheroRandy, Dec 30, 2020.
  1. RancheroRandy
    I did a little welding job today and gas started coming out of the circled hole on the valve that regulates pressure. Any ideas why and how to fix it??? Inkedleaking_LI.jpg
  2. Kiwirancher
    Kiwirancher In Fourth Gear
    Gisborne , New Zealand .
    I think there is a diaphragm in there , may have deteriorated. Not sure from the picture if that reg is serviceable, someone else will know I’m sure.
    Denis.
  3. Jeff B.
    Anacortes, WA
    Not field serviceable. Time for a new regulator.
  4. RancheroRandy
    Thanks for the advice! I will see if I can take it apart....?
  5. 5.0 Chero
  6. RancheroRandy
  7. tony o
    tony o In Third Gear
    orange, ca. usa
    Diaphragm failure is a common problem. Take it to any industrial welding supply and they can get it rebuilt/repaired for you or tell you it can’t be rebuilt. As your welder is red I am guessing it’s a Lincoln brand welder it should be rebuildable , if it’s Harbor Freight plan on buying a new one.
  8. RancheroRandy
    It's a Lincoln 140, not a Harbor Fright...bought off of CL so not sure where the gauges/regulator came from? I'll take it to a welding supply as you suggest....
  9. RancheroRandy
    I couldn't pass up on the 25% discount coupon from HF so bought some China junk that I hope holds up for awhile... :eek: New Regulator.jpg
