Vertical Garage Air Compressor Recommendations
Discussion in 'General Automotive Questions' started by vespaholic, May 20, 2020.
  1. vespaholic
    vespaholic In Third Gear
    Wayne, PA
    My 25-Year-Old, 10-Gallon Compressor is end of life.
    I want to go to a vertical compressor to save some space in the garage.
    Needs to be 110-120V unit.
    Don't need anything to extravagant plus I do not w=want to spend a bunch.
    What are you guys using??
    For Example:
    https://www.homedepot.com/p/Husky-2...IpqSa8IitNxdCJgDk6xoC9_4QAvD_BwE&gclsrc=aw.ds
    OR
    https://www.lowesforpros.com/pd/Kob...e-Electric-Vertical-Air-Compressor/1001014062
    OR
    https://www.harborfreight.com/air-t...e-vertical-shopauto-air-compressor-56403.html
  2. Basstrix
    Mine's 60 gallon and 220V, so I'm no help. I would like to increase storage capacity if I could.
    Edit: 60, not 80 gal.
    [FLAME]I wonder if it's safe to remove the old compressor and turn the tank into a separate storage tank? [/FLAME]
  4. Basstrix
    I was considering buying one I came across on craigslist a while back....my concern is on the condition of the tank if it's not new.
  5. 5.0 Chero
    go for the max SCFM that you can afford
    My home made unit
    The Wrench and Basstrix like this.
  6. vespaholic
    Wayne, PA
    I'll prob. go with the Husky at home depot.
    2-year warranty.
  7. beerbelly
    Often times those oil-free compressors are real loud 'buzz bombs', unless they have the twin pump setup like the Lowes model. Check the DBA ratings.
  8. vespaholic
    Wayne, PA
    Probably going with the Kobalt from Lowes.
    Quiet, dual pump 3-year warranty.
    Thanks
  9. 65restomod
  10. rancheromac
    rancheromac In Third Gear
    I have a 60 gal Porter Cable , 220, it keeps up with high use sanders great ! I have seen most air compressors go bad from heat in small spaces. I put a clip fan on the head to keep it cooler. also keep it drained on bottom and thru gauge/hoses for less rust
