Vinyl plastic sealer
Discussion in 'Non-Automotive Stuff' started by Clark, May 6, 2018.
  1. Clark
    I have use of a huge 8' x 10' heated indoor spa with an insulated roll-up cover:
    https://www.canhottub.com/classic-covers/
    Unfortunately the inner cover (foam insulation sandwiched between vinyl - I think) is deteriorating dropping very small black plastic flakes. Look like pepper flakes. I complained to the manufacturer who says tough s**t - must be chemical deterioration from improper chemicals in the spa (which I highly doubt). A replacement insulated liner runs about $700.
    Is there a flexible plastic/vinyl sealer I can use on this cover material?
    I believe I can cover the inner liner with mylar using 3M 77 adhesive but it would be nice to just coat it instead.
  2. ribald1
    You would want a chlorine bound plastic sealer that is flexible.
    I know of no such product, and even if one were found, getting it to bond with your cover would be another issue.
    I suspect that the cover is not made of vinyl, even if it is advertised as such. I have never seen PVC deteriorate in that situation unless mold is growing on it.
    If PVC cement will soften the material you have, scuff it up with a scotch pad and glue a piece of real PCV vinyl to the underside.
  3. 5.0 Chero
    Looks like you got hosed by them hosers in Canada
    got any pictures of the cover and issue you mite try flex seal.
  4. Clark
    Yeah, thought I might try Flexseal. The cover lasted a full year before it began to flake.
  5. 1965 Ranchero 66G
    If it works as advertised, you might be back in business, hopefully no mold.
  6. Huevos
  7. Clark
    No mold! Dimensions are 96" by 144".
    I was thinking of adding a layer of polyester (PET or PETE) film using 3M 77 spray adhesive. I tried a small spot and it does seem to stick well. One question though is the weight of PET. 0.005" is reasonably priced but no more than 40" wide. Still I don't know if I could handle any material a full 96" wide.
  8. Huevos
  9. Clark
    Solved the problem - for now. I posted a bad review for the company and now they want to send me a free replacement spa cover provided I remove the review. I agreed - once I have the replacement in hand.
    Huevos likes this.
  10. beerbelly
    Nicely leveraged.
