What are these seats?
Discussion in 'General Ranchero Help' started by Ringo00, Jan 11, 2019.
  1. Ringo00
    Ringo00 In Second Gear
    Rensselaer, IN
    Hey guys,
    I bought a 1973 parts 'Chero to help complete the one I already had and these seats were in the parts truck. The foam and frames are in good shape, but I'd like to recover them. Does anyone know what they might have come from or where to get new upholstery for them on the cheap?[​IMG]
  2. scbarger
    scbarger Banner Maker
    McDonough Ga
    Looks like a mid 80s Thunder Bird I had a set in my 71 until I got some fox body Mustang seats.
  3. 1979 RANCHERO GT
    1979 RANCHERO GT In Overdrive
    Looks European. What's the seat track look like.
  4. LSChero
    Yep,could be cougar,Tbird buckets if they have correct tracks.Check with your local stitcher,$250 >ea.depending on style,material.
  5. 5.0 Chero
  6. Ringo00
    Rensselaer, IN
    Thanks guys! The tracks are a direct fit for my 73 Ranchero so they are likely from a 70's Ford of some type. They may even be original to the truck, I've just never seen that stitch pattern before. I wonder if I could use any low back covers from that generation? For now, I just fixed the holes with a vinyl repair kit and dyed them with a can of duplicolor fabric/vinyl spray. I think they will work for now.
  7. colnago
    colnago In Overdrive
    Ridgecrest, CA
    I just saw some seats exactly like that on the 'bay for a Fox Body Mustang. Would have snapped them up, but I love my bench!
  8. HVAC22
    HVAC22 In Third Gear GOLD MEMBER
    Eastern North Carolina
  9. HVAC22
    How complex is the process to apply the dye spray?
  10. Ringo00
    Rensselaer, IN
    I can't vouch for how durable it is, but it is no different that using rattle can paint. I took all the plastic and trim off, then I cleaned the seats with Simple Green and went over them with some rubbing alcohol to make sure they were completely clean and dry. Once they were dry, I sprayed on the paint in multiple light coats until it was covered. I used a full can per seat a let it dry for a couple of days. Once the paint was completely dry, I went over it with some Meguiar's leather and vinyl protectant. It was pretty easy.
    This link is the stuff I used. I cleaned and sprayed the vinyl dash pad to match. As always, "your mileage may vary", but I'm pretty happy with the result.
    https://duplicolor.com/product/vinyl-and-fabric-coating
  11. LSChero
    Like any paint process,the surface has to clean.Once clean,material is wiped down with solvent(PPG) prior to paint coating.I have had good results with SEM paint products.Changed interior color from green to black in my 73 10 years ago.Still holding up well!
    Just restored these door panels last year,they were brown..
  12. TestDummy
    SEM makes the best stuff. I used their argent paint for my grille and other stuff that is supposed to be silver. It goes on smooth and looks OE.
