What were the '64 Ranchero dash options?
Discussion in 'Ranchero Pics' started by Blanco, Mar 7, 2014.
  1. Blanco
    Blanco In Overdrive
    Los Angeles
    I've got a hacked dash where my stereo goes & because of this have been thinking about a dress trim dash option, yet wonder it that was ever offered in 1964?
    Here is what my current dash looks like?
  2. Blanco
    Blanco In Overdrive
    Los Angeles
    Was thinking of something like this?
  3. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    Probably be a lot easier to get a patch to repair the
    existing dash. (About $25 at virtually any Falcon or Mustang supplier)
    First---you would need to locate the trim pieces---and the retaining nuts.
    (probably not gonna happen)
    You would then need to locate a glovebox door (the metal doors are different)
    Then you would need to locate and drill some very large holes in the dash
    (close to 5/8") in 4 places----2 under the radio and two in the end piece near the passenger door.
    I was going to remove mine as the trim is pretty grungy (but in good condition otherwise) until I took it off for painting.
    Way too much work to fill all the holes and source a correct glovebox door.
    So now----I get to send my trim off to a plater to restore it.
  4. Blanco
    Blanco In Overdrive
    Los Angeles
    I figure the only way to repair my dash correctly would be to get new metal & weld it in & grind it all flat & then be forced to repaint the whole dash anyways, don't sound to cheap & easy.
    Don't see it costing $25.00?
  5. ribald1
    Painting the dash without removing it isn't as big a deal as getting the dash out and back in.
    The only hard part is properly masking at the bottom of the windshield area.
  6. HuevosRanchero
  7. Huevos
    Man I Hate Bad Stereo Hack Jobs..
    Seen too many Dash's and Door panels with terrible Machete marks..
  8. MaxInValrico
    Exactly, if you can't do it right, don't do it at all.
  9. T16592
    The deluxe dash option can hide a cut up dash. While you are looking for a 1964, here are pics from my 1965. The design on the surface is different but they are the same under. It's a choice that my be easier than welding in a patch panel :D
    Here is a front view to show how close the deluxe plastic face plate opening covers around the radio.
    Here is a view under the dash to show that the factory drilled holes in the metal dash to mount deluxe plastic face plate.
