Why windshield wipers get sloppy
Discussion in 'Ranchero Pics' started by Clark, Nov 24, 2004.
  1. Clark
    This is why the wipers used to flop clear off the windshield on my '75 GT.
  2. ncranchero
    ncranchero In Fourth Gear
    Denver/Charlotte, NC
    Uhhhhhhhh that would do it!
  3. Rancherous
    Buffalo, NY
    You are the Bushing King lately Clark LOL :D
  4. Dan the ranchero man
    Did you re-bush those assemblies?
  5. Clark
    Dan - No, I just bought a good replacement set from BlueOval. If hard pressed, I believe you might fix a set using RTV. The bearing surfaces are fine. It's the rubber isolators (like A-frame suspension bushings) that go bad. My guess is that the bearings ran dry (I certainly never even knew they were there and could be lubricated) and ripped out the rubber isolators since every single one in the assembly was bad.
    [ November 26, 2004, 08:30 AM: Message edited by: Clark ]
