Wiper switch assistance needed
Discussion in 'Ranchero Tech Help' started by Brett Anderson73, Apr 7, 2020.
  1. Brett Anderson73
    Brett Anderson73 In First Gear
    Denton tx
    I need a wiper switch for my 73 Chero
    the plug was tucked up hidden from sight and after I had found it, it seems the old switch had been broken and part of it was still attached to the plug...
    only has 9 pins, where I believe there should be 10... was a 9 pin switch ever used? Or did a pin break off in the plug??
    I tried uploading photos, but the forum would t accept the file
  2. thebruins
    thebruins In Third Gear
    I think that before 1973 there were 10 pins and after that 9 pins, but I guess it also depends on if the wipers are intermittent/non-intermittent/concealed. I had my 1979 switch falling apart a while back and it has only 9 pins, both the intermittent and non-intermittent version, and those switches are also used for some 1973 applications. What is the part number on your switch?
    Also, if a pin has broken off, it should be still there in the plug and you would definitely notice it missing on the pin-side of the plug.
  3. Brett Anderson73
    Denton tx
    The switch is gone. PO must have taken it out
    all that was there was the black plastic and pins so no part number
    Pretty dark out, couldn’t see well enough to see if any pins were stuck in the plug
  4. thebruins
    Well, if you can, post a picture of the plug and/or switch remnants. I'd be happy to compare it to mine so you would at least know what to look for.
