Wiring Harness getting hot.
Discussion in 'Ranchero Tech Help' started by FordR500GT, Nov 12, 2017.
  1. aquartlow
    I have seen that circuit serviced by a fuse panel installed circuit breaker instead of a "regular" fuse, 35 amp model IIRC. Similar to this:
  2. FordR500GT
    FordR500GT In Overdrive
    Chaparral, NM
    I've never seen that before. wow
  3. andrewok1
    i have one of those on my a/c circut ,works well if things get hot
  4. FordR500GT
    Chaparral, NM
    I would love to have an a/c circuit. Because that would mean I have a/c :D
  5. andrewok1
    WELL ADD A UNDERDASH
  6. FordR500GT
    Chaparral, NM
    Console gets in the way
  7. ribald1
    Just open the window.
    Those circuit breakers are not as fast as a fuse, and you should carry a spare if it is a critical circuit as they do fail. The self resetting type, as that appears to be, can create a fire hazard if hooked to something that is shorted and you don't know it is turning on and off, or ignore it when it happens. That can also cause one of your fusible links to fail, and finding and fixing one of those on the side of the road is not fun at all.
  8. FordR500GT
    Chaparral, NM
    I do open the window. I will also try to utilize the fresh air driver's vent
  9. ribald1
    Yeah, when I was growing up only the rich had A/C of any kind. Stores that had it advertised it out front.
    The "fresh air" vent was always a lie...hotter than opening the window.
  11. FordR500GT
    Chaparral, NM
    We just never had cars that were good enough to have working A/C until now. And the car sucks. (2009 Ford Focus)
  12. FordR500GT
    Chaparral, NM
    Put some dry ice in the vent, then use both the vent and the window.
  13. HuevosRanchero
    had one of those things in my fuse box on the blower....would trip whenever I turned the fan speed higher than speed 3. Regular fuse solved it quite nicely.
  14. FordR500GT
    Chaparral, NM
    Isn't there only 3 speeds anyway?
  15. ribald1
    With Georgia weather, you need to turn it up to 11.
  16. FordR500GT
    Chaparral, NM
    Texas, too.
