Workin on the PYL
Discussion in 'Ranchero Pics' started by 5.0 Chero, Sep 8, 2007.
  1. 5.0 Chero
    This is what I have been working on this week.
  2. trikar
    trikar In Maximum Overdrive
    San Bernardino Mountains
    Where is the top mounting to?
  3. 5.0 Chero
    A 2 piece cup assembly. in Case I need to adjust hight and so I can change bag if it blows with out removing any suspension. (be able to change on side of road with hand tools and a jack) If I have to pull it back apart I will take some pics of what I made.
  4. trikar
    Yes!
  5. TestDummy
    I'm pretty sure a pic compressor won't work. I'm thinking some kind of air system. Carl?
  6. Dan the ranchero man
    I have a dumb question. Why are you doing this? for ride quality? Or just for fun?
  7. 75 Squire
    Let us know how that custom fab. job for the shocks works out. Very neat instal there. Kinda thinking about a air bag set up for mine. But thats a long way off.
  8. CJ Guy
    CJ Guy In Maximum Overdrive
    Space, The final Frontier
    I'm sure I'll get corrected, but those air bags are independently filled with a common air hose. Use for ride hieght and weight control.
  9. GregoryM
    GregoryM In Fourth Gear
    Federal Way, WA
    Not trying to flame your design there but that lower shock attachment looks a bit tenuous. The strut rod is designed to take a (primarily)tension load. Your shock mount introduces a shear load, albiet near the end. Do you really want to do that? How about installing a stud on the lower control arm somewhere to accept the lower eye of the shock? Also, those small u-bolts are mild steel aren't they? There is nothing locating the lower position of the shock other than the clamping force of those u-bolts. I don't think they will stay put for long. Just my .02.
  10. 5.0 Chero
    Upper mount parts
    Bag mount
    Spacer
    Lower bag mount
    [​IMG]]
    Slammed
    Raised
    [ September 08, 2007, 07:20 PM: Message edited by: 5.0 Chero ]
  11. 5.0 Chero
    using the old A/C compressor plumbed to a tank behind the seat.
    All of the above........Not a dumb Question.
    More or less I have enough valve to control all 4 bags separately but I have had the back hooked together for about 5 years now and it seem to ride ok.
    Dodge trucks run their sway bars of the struts this should produce the same load I would think. could not really locate the lower mount any where else and have it clear all the other parts if it had a lower a arm it would have been a lot easier..
    the U bolts are temporary As is mount waiting on clamps to come in an have to pick up some heavy wall tubing to remake the lower mount.
    [ September 08, 2007, 07:09 PM: Message edited by: 5.0 Chero ]
  12. 5.0 Chero
    Also looks like I will have to relocate the holes on the upper bag mount to move the bag in about 1/4 of an inch as it rubs the frame horn when fully inflated, :(
  13. CJ Guy
    Nice, I like it...
  14. Clark
    Yeah, I like that too.
  15. 5.0 Chero
    Yes it the sanden style that came on the 5.0
    if you look you can see I used a K&N style air cleaner breather on the inlet
    Its about 3 gal. it was a air brake tank from a big truck. if Idling it takes a min or 2 min to fill going down the highway it runs for about 5 seconds I am using a 140 off psi switch it kicks on at about 120..
    I do not think the oil from the A/C side of the compressor would still be their I have been running it for about 2 years now with no problems
    [ September 09, 2007, 07:13 AM: Message edited by: 5.0 Chero ]
  16. pdw72
    pdw72 In Maximum Overdrive
    southeast MN
    Sweeet!!! What a PYL :D :D :D
  17. burninbush
    Now, that's sweet. Got me thinking that's what I really want on the front of my car.
    I also don't like that lower shock mount -- I think a pro welder could attach some permanent brackets without damaging the strut -- and then you could put the shock's forces directly above the strut. You might get away with it forever as you have it --
    I wonder if you plan any attempt to measure how much weight each wheel is carrying? Trying to figure out how you manually set them if they are all independent.
    Anybody have a strategy for determining that weight-per-wheel?
    Citroen [many years ago, DS-19?] had a very interesting combination hydraulic and air suspension -- ride height and shock rate could be set by the driver while in motion.
  18. 5.0 Chero
    The air horns I am using are twins off of a 69 Ford F700 I Am running a 1/3 gal pony tank with the solenoid about 6 inches away from the horn will be mounted behind the tucked bumper.
    [ October 01, 2007, 02:26 PM: Message edited by: 5.0 Chero ]
  19. 5.0 Chero
    closer to horn the better. the pony tank will be fed from the main tank behind seat. just wanted the extra volume at the horn.
  20. 75 Squire
    If Im not mistaken the airbag itself also takes up a certain amount of the shock. I know theres a bag system where you dont need shocks at all. If its that big of a deal Im sure theres a way to fab up a dual shock set up and have them attached directly to the lower arm.
