WTB - 68 steering column
Discussion in 'Ranchero Parts Wanted' started by Unclebrad, Aug 14, 2023.
  1. Unclebrad
    Unclebrad In Fourth Gear SILVER MEMBER
    Concord, CA
    Looking for complete, operational, steering column (with automatic shifter) for my '68 Ranchero (with 390 and C6 transmission), including neutral safety switch. (Don't need the steering wheel, but pretty much everything else right down to the rag joint.)
    Thanks!
    Cindy likes this.
  2. pmrphil
    Wouldn't the neutral safety switch be on the trans? I know the C4 is there.
  3. RANCHEROROB
    Pueblo de Los Angeles, Aztlan
    A c6 trans it's on the column.
    I doubt you will ever find a good column for any 60s ford.
    The ford columns from the 60s 70s were shakey from new and had a habit of slipping out of park.
    That is the reason they usually have a sticker someplace on the interior telling you to set the emergency brake.
    I would try to adapt a new universal tilt column.
  4. Jeff B
    If you were to go with a new universal column, choose carefully. The are few vehicles I have worked on with those and some are not made that great. Can't recommend a brand because there have been no markings on any of them to ask questions or find parts. Good luck.
  5. Unclebrad
    Concord, CA
    Although the universal has some appeal, I definitely want to go with original equipment.
  6. Unclebrad
    Concord, CA
    Still looking.
  7. LSChero
  8. Unclebrad
    Concord, CA
    LSChero likes this.
  9. Unclebrad
    Concord, CA
    Still hoping one will become available.
