Ranchero USA
Go Back   Ranchero USA > Ranchero > Ranchero Tech Help
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
Ranchero Tech Help Tech Help for your Ford Ranchero
Reply
Thread Tools Display Modes
Old 11-06-2008, 07:36 AM   #1
rangerlrp11
Member
rangerlrp11's Avatar
Default install AOD to 400M
Has anyone went from C4 to an AOD transmission with the 400M engine ?
I want to install in a 79 Ranchero
thanks mike
rangerlrp11 is offline   Reply With Quote
Old 11-06-2008, 08:03 AM   #2
72GTVA
Administrator
Default
thanks mike
A few have talked about it but haven't seen any posts - but... check out this thread: http://www.ranchero.us/forums/showthread.php?t=3999
This was an FMX to AOD change and I think a lot of the information will be useful to you. Wish Hyrb was still around to lend his assistance with these issues.
72GTVA is offline   Reply With Quote
Old 11-06-2008, 10:31 AM   #3
rangerlrp11
Member
Default Aod w/ 400M
72GTVA
Thanks for the info--I did download this information--my transmission man
tells me I would need an adapter to bolt up ?
Old 11-06-2008, 10:44 AM   #4
72GTVA
Administrator
Default
72GTVA
I don't know - I've got mostly 4 Speed cars or I run a beefed up C6 - When I do convert the power train on one of mine it will be whole package - engine, trans, rear gear, electrical so I really haven't researched it. Hoping someone else will wade in that maybe has done this one.
It seems to me though that the 400M was around for a long time and was available with AOD transmissions - would think you could find something that would bolt right up such as a AOD from an F-Series or Lincoln Product.
Old 11-06-2008, 10:54 AM   #5
Fomoco8
Senior Member
Fomoco8's Avatar
Default
http://www.network54.com/Forum/260730/ Mike try asking that question on the site on this link ..those guys have done them all
__________________
Spence "Faster Damn It!!"
My 78 GT "The Beast"
Fomoco8 is offline   Reply With Quote
Old 11-07-2008, 08:22 AM   #6
rancheromeister
Senior Member
Default
You will need an adapter plate or bellhousing;the 351m and 400 use the 429 and 460 bellhousing bolt pattern. I believe the early 400s used the small-block pattern.If you go deep enough into the site Spence told you about, you'll find the info you need. There was a thread on this awhile back.JD
rancheromeister is offline   Reply With Quote
Old 11-07-2008, 03:25 PM   #7
rangerlrp11
Member
Default 79--C4 to AOD w/ 400M
I have asked for info on the transmission site , and will be looking through
their information thanks mike
Old 11-11-2008, 11:01 AM   #8
rancheromeister
Senior Member
Default
www.artcarr.com has a bellhousing adapter for 400/460 $408.
www.ford-aod.com has trans parts, and model year recommendations. JD
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
