Ranchero USA
Go Back   Ranchero USA > Ranchero > General Ranchero Help
Register FAQ Members List Calendar Search Today's Posts Mark Forums Read
General Ranchero Help General Discussion about the Ford Ranchero
Reply
Thread Tools Display Modes
Old 08-17-2010, 09:57 PM   #1
Hal
Member
Default selling price of rebuilt 351c
Hi:
Does anyone have an idea of what a rebuilt 351c 4V long block without carb should sell for?
Thanks, Hal
Hal is offline   Reply With Quote
Old 08-17-2010, 10:18 PM   #2
Mooretorinos
Senior Member
Mooretorinos's Avatar
Default
It cost around $2500. for a complete rebuild including heads.
Mooretorinos is offline   Reply With Quote
Old 08-18-2010, 06:37 AM   #3
ribald1
SITE SUPPORTER- PLATINUM PLUS
ribald1's Avatar
Default
There are a lot of different jobs that are called a "rebuild".
From just a ring and bearing replacement and valve job on the bottom end, up to the sky is the limit.
__________________
Quote:
Originally Posted by burninbush View Post
Crap is real, though, I believe in that.
The uncontested absurdities of today are the accepted slogans of tomorrow. They come to be accepted by degrees, by precedent, by implication, by erosion, by default, by dint of constant pressure on one side and constant retreat on the other - until the day when they are suddenly declared to be the country's official ideology. ~ Ayn Rand
ribald1 is offline   Reply With Quote
Old 08-18-2010, 08:57 AM   #4
72GTVA
Administrator
Default
Quote:
Originally Posted by Hal View Post
Hi:
Thanks, Hal
That is sort of a nebulous question - and requires a little more information to give you a really good answer. Is this an engine offered by a production rebuilding engine company or is it a custom machine shop effort? Production shops produce rebuilt engines largely to a common industry practice set of standards which are largely equivalent to a simple bore/ring/main & rod bearing/crank grind/valve job and may or may not include new camshaft. If a smaller shop has taken on the task of rebuilding it there is likely more attention to fine details and might including working to a tighter set of tolerances and better precision in the fit and assembly of parts.
Using some local shop options from here, a true 351 Q or R code with 4 bolt mains and the correct or nearly correct cam, with just the bare overhaul it would be in the neighborhood of $1,500 to $2,500 Rancherobuck$$$$ for a long block. The assumption here is they had a complete core engine and rebuilt it to common industry standards and practices using the typical vendor prices on common replacement parts. This would not include "better" pistons and such.
If this was a rebuild that used big name components such as Keith Black or (name that supplier) pistons, internally and externally balanced, blueprinted, and performed precision measure/fitting of all replacement components, and added features such as dyno tuning and break-in you are looking at something in the neighborhood of $5,000 to $10,000 Rancherobuck$$$$$ or more.
Let us know the "pedigree" of the build if you can - who built it, what did they use in major components and we can then probably come up with a better estimate.
72GTVA is offline   Reply With Quote
Old 08-18-2010, 10:01 AM   #5
Gremium7
SITE SUPPORTER- GOLD
Gremium7's Avatar
Default
Hi:
Thanks, Hal
Hello Hal
i have buy a Marschal rebuild long Block in Ca. by http://www.car-stuff.com/
for me it was ceep !!
__________________
Ride a Ford Ranchero 1972
400 6.6 Engine number( D7TEA2B old ) rebuild Marschal Engine and C 4 Trans with Bigblock Bell Housing
Vin Code 2A47H21618029222
http://www.supermotors.net/16180
Gremium7 is offline   Reply With Quote
Old 08-18-2010, 07:54 PM   #6
Hal
Member
Default
Hi:
Thanks for the input. From what I can gather, the rebuild was done with "standard" parts. The block was bored .030 over (first overbore from stock) and the crank was ground .010 under. A new cam (RV ? don't know the lift or duration characteristics) was installed and of course all new lifters, bearings, timing chain, etc (the usual stuff). The heads were redone with new valves, springs, guides, etc. The stock intake manifold was replaced with an Offenhauser hi-rise (compatible with a 4V). That's all the information I was able to get. Does it help?
Thanks again, Hal
Old 08-18-2010, 09:29 PM   #7
72GTVA
Administrator
Default
Yes - that helps. Assuming a production rebuilding facility and including the "core" cost of a 4V engine (hopefully they didn't swap blocks on you) would estimate its worth at $1,500 and $2,000. That is about the cost if you were to rebuild it yourself having a machine shop do only those things that you could not do yourself due to tooling and such.
Old 08-19-2010, 01:21 AM   #8
burninbush
Senior Member
burninbush's Avatar
Default
Just for info, is there some reason a Cleveland rebuild labor should cost a lot more than other Ford v8 motors?
I think I paid $695 for the 302 long-block in my car, from a company near Los Angeles. Everything that moves in it was either new or rebuilt, brass core plugs, new oil pump, gasket set, etc., and it came with a warranty. Three years later it still seems perfect. [United Engine in Compton, CA]
burninbush is offline   Reply With Quote
Old 08-19-2010, 06:03 AM   #9
72GTVA
Administrator
Default
Just using the general price the local rebuild company sells the Cleveland rebuilds. Suspect it is due to the dwindling supply of available engine cores and the cost of the significant parts that are unique to the Cleveland. How long have 302/5.0 engines been in production in comparison to the 4 years or so that Cleveland engines were produced?
Old 08-19-2010, 08:54 AM   #10
Denny
SITE SUPPORTER- SILVER
Denny's Avatar
Default
If you look at the link that Gremium posted above, you could get a 429 longblock for under $1500. They also showed two or three versions of a 351 for about $1200 but I'm not sure if it specified Cleveland or Windsor. Might be something to think about.
I would only consider paying more than $1000 for a "rebuilt" engine if it had a warranty that I was sure would be honored, or I at least knew (and trusted) the person who rebuilt it. I've heard of too many horror stories about people who bought a pig in a poke.
Denny is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
