1965 4spd steering column
Discussion in 'Ranchero Parts Wanted' started by tntski, Jan 17, 2022.
  1. tntski
    tntski In First Gear
    I am changing to a 4 spd toploader and would like to find an original manual steering column.
    No shift collar on the column.
    Not interested in after market columns....
  2. pmrphil
    you do know that the column is part of the steering box, right? They are one piece. How about just changing the collar? way easier and cheaper.
  3. tntski
    pmrphil - thanks for the reply.
    I do understand that they are an integrated piece, I was trying to get rid of all the auto shifter parts from the column itself.
    Having said that do you know if I can rebuild the column and delete the auto shifter arms and associated parts when I reassemble the column.....
  4. pmrphil
    Don't even have to take the column out, disconnect at the bottom, and just change the collar - no need to remove the tube. If you wanted to cut the arm off at the bottom, so be it.
  5. tntski
    Thanks
  6. RANCHEROROB
    Pueblo de Los Angeles, Aztlan
    The column collar flange on 65 - 66 mustang should be the same as falcon.
    It's smooth with no shifter.
    A mustang supply probably has them new and tell you if it fits.
  7. tntski
    Thanks for everyones help. I found what I needed.
  8. Mikey likes it
    Mikey likes it In Second Gear
    so what do I do with my worn out 1962 3 on the tree column/ collar?
