1978 Ranchero upgrade issues need some advice.
Discussion in 'General Ranchero Help' started by Clay, Jan 21, 2020.
  1. Clay
    Clay In First Gear
    Having issues, need advice. History. Have this 1978 ranchero it has a factory equipt 351 windsor, recently swapped out the old cast iron 2 barrel intake with a aluminum edlebrock performer, a holly 650 carb, all emissions / smog pump removed, and hooker super competition headers installed have had issues with it overheating so I replaced 180 thermostat with 160. Seems to be going better now. Has horrendous backfire on acceleration, wondering if that could be timing. In hindsight seems like timing should have been checked after 4 barrel swap. What say ye?
  2. 72GTVA
    Yes, suggest a thorough tune-up - check timing, mixture, base idle, fast idle, etc.
    Edited to add, suggest you also check for vacuum leak around the new manifold.
    How was it running before the work was performed?
