door tag
Discussion in 'Ranchero Vin Decoder/Production Numbers' started by Brian Engel, May 4, 2008.
  1. Brian Engel
    Brian Engel In Second Gear
    Give, Denmark
    I finally got some time to look at my H-code from pacoima, it must have been driving in sunny ca all of its life the frame looks absolutely new no scratches or rust and the body has only 3 tiny rustholes in the left floorpan along with the smashed rear bumper and left rear quarterpanel, a new grille, molding, weatherstripping and some loose ends in the wiring and it will be as good as new. Need some help with the door tag, thanks:
    body= 97D
    color= 28 or Z8
    trim= UAA
    trans= w
    axle= 6
    dso= 71
  2. 72GTVA
    97D = Ranchero 500
    28 or Z8 = (How About 2B) - Bright Red
    UAA = Black, Bench Seat
    W = C4 Automatic Transmission
    6 = 3.00:1 Conventional Axle
    71 = Los Angelas
  3. Brian Engel
    Give, Denmark
    okay thanks:D, I think the former owner has changed the tranny cause it sure looks like a c6 thats sitting on it now:)
  4. 72GTVA
    I gooned up the tranny - it is supposed to be a C4, I skipped a line in the shop manual...
  5. TestDummy
    What's with you 72 owners and your 'codes'?
    Q-code, H-code. So an H-code is basically a standard, run of the mill, Ranchero?
    I'm going to see what 'code' my 71 is. Maybe it's an S-code. Yeah, that would make me cool :)
  6. 72GTVA
    No amount of anything would make you cool, although under some circumstances you might be able to come up with some "pesonality", if you went to Mexico or the Philippines with a large wad of money.
    Many are naturally cool, the rest were born and lived in or around Detroit.
  7. TestDummy
    Pesonality! I have plenty of pesonality, mister. Sometimes three at once.
  8. fomocomofo
    fomocomofo In Fourth Gear
    hey sean i think your avatar has a main bearing knock
  9. Giska1
    No its his personality that knocks, he he :D:rolleyes:
  10. Charlie's 65
    Charlie's 65 In Second Gear
    Philly,Pa.
    vin # decode
    can anybody help decode a 70. F0A4H273999F
  11. Giska1
    You are missing one # after the 4 it will tell if its a 500, GT or Squire.
    but the 0 are 1970 A= Atlanta plant and the H are 351 the rest are just a number that are special and unique for your car.:)
