Engine oil
Discussion in 'General Ranchero Help' started by Saff54, Jul 17, 2021.
  1. Saff54
    98FF3CD4-5970-421A-98D5-41A8D9192532.jpg Afternoon all,finally getting closer to getting my 67 out and about,new rebuilt 390 crate motor just arrived,lots of break-in directions,they provided cam break in lube and said to use either 30 weight,15/40 or 20/50 detergent oil,run engine for 20minutes at 2000 rpms to break in cam,it’s an isky racing cam,any thoughts on oil?they recommended shell oil and of course ZDDP,I’ve always used Lucas hot rod oil that already has zinc in it,they told me that the Lucas hot rod oil is a synthetic,I went to my auto parts store and looked at it and I don’t think it is?don’t want to do the wrong thing and void the warranty,any thoughts or suggestions would be appreciated,should be between 340-360 horsepower 3A77CE1D-3C21-4927-AE13-4E7636769AE5.jpeg
    Buds 67 and LSChero like this.
  2. pmrphil
    I'd try and get some Driven (ex-Joe Gibbs) break in oil, it's called BR, it's a 15W50 break-in oil with the correct amount of zinc, phosphorus, moly, and other additives made just for breaking in cams, seating rings, etc. That's all I will use in a fresh engine. The Shell Rotella no longer has the correct amount of zinc required for break-in, I'm kinda surprised that someone still recommends it. P.S. I don't think Lucas is synthetic, either.
    Buds 67 likes this.
  3. Saff54
    Hey Phil,I’ll look into it,thanks
    Buds 67 likes this.
  4. beerbelly
    Buds 67 likes this.
  5. Saff54
    Thanks BB,interesting,everything you need to know about oil but was afraid to ask!,very informative,I always used Lucas hot rod oil,wonder if that attributed to it demise,Phil,summit has the break in oil you mentioned,gonna check into it
  6. Saff54
    The VR1 got great reviews and it’s readily available in my area,think that’s the way to go,thanks!
    Buds 67 and beerbelly like this.
  7. Boiler92
    Indiana
    I read more by this guy about break in oils. He basically says the high zinc break in oils are junk and not necessary even for flat tappet cams. I was just about to spend $100 on a case of Driven break in oil but I'm not sure now. Any thoughts?
    Here's the article: https://www.corvetteforum.com/forum...9-test-data-on-9-different-break-in-oils.html
  8. Boiler92
    Indiana
  9. Boiler92
    Indiana
    After more research I too am leaning toward's BB's Valvoline VR-1, 10W-30 for break-in and post break-in. It has the higher level of zinc recommended by Melling for my cam plus excellent wear prevention. Despite what the blogger says I'll probably still do the 2000 rpm break-in for 20 minutes then change the oil and filter, then 500 miles, then change again.
    Buds 67 likes this.
  10. Hillbilly
    Probably think I am nuts for spending what I do on engine oil, but having no oil related failures means a lot to me considering the replacement cost of some of my engines. From the lowly lawn mowers, the tractors, trucks, everyday driver cars, to the 427's and Boss 9's - - All of my junk is protected by various versions of Schaeffer's Oils. Zero failures for many years now. ( http://www.schaefferoil.com )
    Buds 67 and pmrphil like this.
  11. Boiler92
    Indiana
    It looks like the oil blogger tested 2 types of Schaeffer's oil for wear protection. One is ranked 147th and the other 224th on his list. See link above.
  12. LSChero
    Motor looks good Saff!Is that a blue monkey build?
    Like Hillbilly,been using same oil for years on all my rides with no issues.(mobil 1 full syn.)I use a good 30w for break in.Get oil primed to lifters just before first start,run for 18/20 minutes at 1800/2000 rpm,change oil/filter while still warm and refill.
  13. Hillbilly
    Don't know what to think about that rating. A buddy ran a test on a batch of the semi-synthetic Schaeffers using a 94 Lincoln 4.6 engine. We used the pee bottle send in a sample for wear metal analysis method every five thousand miles. At twenty thousand miles the oil still checked at 70 percent good with no engine wear showing. We changed the oil and filter anyway as the oil was just starting to change from it's green tint to red. Engine is still going strong at a bit over 250 thousand miles using Schaeffers 7000 series 10 W 30 the entire time since new.
    Buds 67 likes this.
  14. Saff54
    Sooo..should be installing the engine on Wednesday,hoping to start it up next weekend,my mechanic friend has been slammed but it looks like we’re good to go,Phil I’m going with your suggestion and got the driven break in oil,should I replace right after the initial break in ?ie 2000 rpm for 20 minutes to break in the cam,been getting conflicting answers,one says,after 50 miles,another said 500?as always thanks for any help or suggestions!
    Buds 67 likes this.
    I've always told customers 500 miles, with only one comeback that was the customer's fault, but just whatever you're comfortable with.
  16. beerbelly
    If you don't already have a magnetic drain plug, that might be something to consider also.
  17. pmrphil
    Normally after the cam break-in period I do one more heat cycle (driving or stand still) and then at least change the filter and add a quart, drive another 100 miles or so and do a complete change. Oil's cheap when compared to the cost of a rebuild or repair. Remember to not beat the heck out of it on the first drive. :p
    The Wrench likes this.
  18. beerbelly
    Yes, don't do this....:p
    Saff54, Buds 67 and pmrphil like this.
  19. pmrphil
    HEY !! That wasn't the first drive :cool: :D
    Saff54 likes this.
