Fuel Tank
Discussion in 'General Ranchero Help' started by brawleyw, Jul 27, 2014.
  1. brawleyw
    brawleyw In First Gear
    Charles Town, WV
    I am not sure the fuel tank in my 1971 Ranchero is repairable so looking for suggestions on where to find a replacement. Does any one know the dimensions of the tank or if one for another model Ford will fit?
    Thanks
    Slap in a 32-gallon Bronco tank, and you'll have some real range!:D
  3. Tim70ranchero
    Tim70ranchero In Overdrive
    Ohio
    Good Luck finding a gas tank. It took me years. I put a fuel cell in the bed to use until I found a tank. I found tanks down south or out west, I just couldn't find anyone that would ship one. I got lucky years later and found a clean one within driving distance and bought that.
  4. RANCHEROROB
    Pueblo de Los Angeles, Aztlan
    They do make new tanks for Fairlane, Comet, Torino, Mustang ect. The Ranchero tank is basically a drop in tank turned upside down with different filler ,vent holes ect. It would be very simple for the company that makes the fairlane tanks to modify a tank to fit a Ranchero. Maybe if a few people contact Spectra Fuel Tanks they would make Ranchero tanks.
    http://www.spectrapremium.com/products/fuel_tank.html
  5. JKG-R500
    JKG-R500 In Third Gear
    Marietta, GA
    If push comes to shove, a tank coating is available and can be applied with a little bit of elbow grease. The coating can be had from most motorcycle shops, complete with instructions, including to ..."clean the tank..." which should go without saying. Have the tank dipped, in a non-acid solution, then pressure checked for pin holes at your local radiator shop. There is at least one national-known parts house that sells the coating but their instructions are just a tad lacking.
  6. Tim70ranchero
    Ohio
    I was quoted $350 to clean & coat my tank, with no warranty. For that much $ I just put in a aluminum fuel cell in the bed, and it wont leak for a long time coming.
  7. Bryan59EC
    Bryan59EC In Overdrive
    San Antonio, Texas
    Had the tank in my ranchero cleaned and coated a few years ago
    A truck radiator shop did it for $125
    Will probably have to do it again soon----left it sitting with about 1/2 tank for obout 2 years.
    pretty new sending unit pretty much rotted away.
  8. TestDummy
    Of the three 70-71 tanks I had, one was good. I gave one, years ago, to a guy who had it cleaned and coated. Cost him like $150, sort of what Bryan got done.
  9. Felipe
    Felipe In Third Gear
    Northern California
    I just replaced my tank in my '79. I think I paid $130 to PartsTrain.com but there were numerous outfits that sold it for about the same amount. I just a Google search and I got loads of hits. The fuel sending unit was a different story. Only one company had it. It was ClassicCarAutoParts.com that had it. Your Ranchero is older, so best of luck.
