Key replace.
Discussion in 'Ranchero Tech Help' started by Woodsy, Mar 13, 2021.
  1. Woodsy
    Woodsy In First Gear
    Any ideas on replacing a lost key? Need a key to be able to move. Thanks.
  2. Hillbilly
    Locksmith. Cheaper to have a good locksmith sort out the correct key than it is to repair a damaged steering column.
  3. Woodsy
    Thanks. Wasn't sure that was an option being so old.
  4. 1979 RANCHERO GT
    If your door key is the same as the ignition key, open up a door and take a door cylinder to a locksmith . They can make you a key without a outside service call fee and you don't mess with the column . Cheaper
    The Wrench likes this.
  5. Woodsy
    Yeah i believe it is different. Thank for the heads up.
