Had an “upgraded” gasket put on with Carb, in October, one thick one compared to the two prior person put on. But it’s got a leak… and the leak is orange. Wondering if it’s the winter storage gas stabil making it orange? Will need to circle back around to original style of gasket. Days photos here, had the new carb dialed in, it has been at high idle…came back from lunch, cold start, wouldn’t turn over and then noticed the leak …(two different things …one not impacting the other outside of needing to replace gasket before making final adjustments). https://drive.google.com/drive/folders/1-FKYtre0S6nW3CKZUEzd1QVjIpFkfYO4
I never use any of that gas stabilizer, just non-ethanol gas during the winter and haven't had any problems...I would once a week run it for 10-15 mins to bring up temp (never above 140 degrees thanks to my upgraded cooling system) and maintain the battery charge....just me....
