basically just an organizational tweak on what's there, as it expands it'll get hairy to find what yer lookin fer there could be an open thread for nominations to be made sticky, and the rest of the section would be sticky, 'read only' threads that have won the approval of a moderator. each thread could be a general topic and each post to the thread could get specific with brands, manufacturers and part numbers... Electrical could be a thread and all kinds of posts could follow it like starters, dash clusters/harnesses, alternators/charging systems, fusible links, circuit protection, how to troubleshoot engine swap interchange... 6 cyl, 90* V8, FE, Y block, 335 series, 385 series, brackets, P/S pumps, intake/head interchange, exhaust mans/headers, mounts trans swap interchange, bell patterns, flexplate/flys, converters, AOD info, slipyokes, shifters, manual trans, speedo gear info, mounts interior... what seats fit, consoles, carpet dealers, door seals, window felts, seat belts driveline/brakes... rear end swap info, spindle interchange, master cylinders, calipers, rotors, drums, wheel bolt patterns body/exterior... panel interchange, glass, tailgates, bumpers, wheels/wheelcovers, stripe kits, chassis... springs, control arms, urethane kits, body mounts, shocks, mufflers, steering/boxes, gas tanks cooling/airconditioning... radiators, heater control valves, heater cores, evaporators, condensers, compressors, dash controls, vent doors, vacuum motors, blower/fans, yada yada yada
