Help please any decoding the numbers VIN 6K290145717 Body 66B Color T Trim 45 Date 03M DSO 53 Axle 1 I think maybe "I" Trans 6 thanks in advance
VIN 6K290145717 6=Model year of production,1966 K=Assmbly Plant,Kansas City 29=Body style code,My books do not cover that year's body code for VIN O=Engine code, I show an engine code for the 62 model year as bing a 390, I am not 100% sure that is the same for '66 145717=Unit number of production at that Assembly plant for that year. Door data plate code Body 66B=Body type, Custom Ranchero Color T=Body color,Red Trim 45=Interior trim, My books don't go back far enough to cover that code color. Date 03M=Production date 3rd day of December. Axle 1=Rear Axle Ratio 3.0:1 Trans 6=Trannsmission code,C4 Automatic3 speed Dual Range . If the Data plate has a black background identifies a unit painted with M32J(Acrylic)Enamel (Solid color Unit or the lower Body Color when Unit is two toned). If the Data plate has a gray background it identifies a Unit painted with M30J(Non-Acrylic)Enamel. (Solid Color Unit or the lower body color when unit is two toned).
triker, Thanks for the info, the motor in the Ranchero is a 289. it looks to be there from the factory.
I was just informed from a very reliable source that there was no engine code "O" for 1966. "C" would be the correct code for a 289 2V in 1966. [ September 09, 2007, 04:05 PM: Message edited by: trikar ]
Thanks, However I am sure it is an "O" it is the door data plate and the radiator brace and my title. I will keep digging to see what I can find....thanks for the help....matt
You must have gotten those eyes from the same place as me, I can't read small print without glasses anymore.
