460 fan shroud
Discussion in 'General Ranchero Help' started by Clark, Nov 12, 2023.
  1. Clark
    Any chance this fits my '75 GT? There is no part number on my fan shroud.
    https://www.ebay.com/itm/134756509982?_trkparms=amclksrc=ITM&aid=777008&algo=PERSONAL.TOPIC&ao=1&asc=20230811123856&meid=d43b253bbd8d4b9e84b950428b2d1d6d&pid=101770&rk=1&rkt=1&itm=134756509982&pmt=0&noa=1&pg=4375194&algv=RecentlyViewedItemsV2&brand=Ford&_trksid=p4375194.c101770.m146925&_trkparms=parentrq:c6a1a8fa18b0a8cd7948eddafffdc154|pageci:1e707afc-81d1-11ee-99bf-5a1bd6dadb96|iid:1|vlpname%
    My fan shroud has split and been patched together several times with fiberglass. It really got butchered when forced into an undersized aluminum radiator. So I'm patching up yet again.
    I tried to get a Ford replacement years ago but none were available. This ebucks offering would be ok except I think the $90 shipping is ridiculous.
    Oh I could go with electric fans if I had to, but not yet.
  2. 1978GT
    Per the MPC, fits full size but not Torino/Ranchero.
  3. Clark
    Thanks 1978GT. I figured as much. That 1974-76 460 fan shroud was never available even years ago.
  4. 1978GT
  5. pmrphil
    Wow, they're still around !! My brother dealt with them many times for parts for his 78 Continental, quite a few years ago, he spoke highly of them then.
  6. Clark
    Thanks 1978GT. I'm checking for pricing now.
  7. Clark
    Ask Rear Counter for a quote on the fan shroud but have heard nothing. Luckily I've kept working on mine and have it pretty well patched up.
  8. Clark
  9. rancheromac
    rancheromac In Third Gear
    years ago, Aquartlow told me and i got, 98 windstar fan setup which includes a shroud, 2 16" fans, 1 pusher 1 puller. fits and looks perfect ! only a little cutting around hose inlets. he also showed me the relays needed. it may be a sticky on this site. get brand new for $125 maybe he will chime in
    I had a '95 setup, but I sold it to a Fullsizebronco forum member. Now I can't even find any Windbags at all at the junkyards.
  11. aquartlow
    Both fans installed into a factory/aftermarket '95-'98 Windstar dual electric fan radiator cooling fan assembly are "puller" style of fans, I'd probably never recommend a pusher style of fan, too many things working against this design of fan to get optimal cooling.
    The '95 was a dual puller setup; I think the late '90s Taurus fans are the same design.
  13. Jeff B
    I used a Crown Vic fan and shroud on my '70, but end up cutting the shroud down until it fit inside
    the original shroud. Moves a lot of air and motors and fans/blades are available.
  14. Dan the ranchero man
    The 72-76 Thunderbird with 429/460 will have a bolt in fan shroud for the rancher with a 460. The Lincoln mark from the same year's will work as well.
