About ten minutes ago my chero just went dead, lots of gas but no spark? can anyone help me out it's a mallory ignition
hehe yes that could be a solution but I have been driving in it for a couple of days without problems
Check out if its a positive current to it, measure the voltage, if none try to provide directly from batt. just to test it, you can test the coil by 1 from the Pos. to the coil han just hit it with the neg. on the terminal if its a spark its ok if not its the coil. I've done it a few times, remember i'm riding a Harley
checked all your advise no kill switch, no broken fuses and it looks like it's the coil, no spark in the center wire from the coil, thanks for your help
The coil may be OK. You do not identify what type of "Mallory" ignition you have. The defect could be there.
Get a test light. Attach ground lead to bare meal ground, insert probe in the negative, or 'tach test' lead. Crank the engine, and see if light flashes. If light flashes, or no solid light, replace coil. Solid light, not flashing-module or pickup in distributor, distributor cap, or rotor. Rotor is most likely culprit. JD
found out what model it is, it's a mallory unilite and I think it's the ignition module that's burned out, thanks for your help guys
